Good points on both sides. When one hears of an ink available at half the price, one immediately thinks or feels that they might be at a disadvantage on pricing/quoting if one's competitors are using the cheaper inks. On the other hand, as Gino has pointed out, it's a small part of any given job. On the other hand, the Tech took away about ten empty 440 cartridges yesterday for recycling; there's a $700.00 savings right there.
If there's a 3rd party ink developed which has no deleterious effects on a printer, then it's a no-brainer, but unfortunately only time will bear that out.
I said I'd stay out of the 3rd party ink debate for the duration, but I will add this.
Reps, techs, whatever you call them are in business to make money for themselves or the company, period. NO matter what you are BUYING everything is sunshine and roses until something F's up.
That's when you find out you are an imbecile and not using their products correctly.
When will people learn this simple fact: When money is flowing from your pocket to theirs the world is a perfect place and you're their best buddy. Try to get help afterwards and they don't know you.
True that. I experienced the banding in the test print within the first year, yet the dealer who I bought it from (who was all gushy making the sale) nor Roland did anything for me.
I think a moderately high volume of printing and a colour calibrated workflow are pre-requisite to 3rd party inks. If you're a small shop and you're running your printer on stock ICC profiles, 3rd party inks will more than likely turn into a nightmare.
Yes, that's one point I failed to mention; it does seem to be agreed that a high volume shop can get away with 3rd party inks, but for a printer that might frequently sit idle for a few days through the year, the OEM inks seem to be the better choice. I'd like to know exactly why that is though. Is it the type of solvents used, or what?
3rd party ink suppliers constantly exclaim: "We are exactly like OEM just plug and play. Never any mention of color calibrated workflows or other exceptions to avoid "issues".
Now you'll need to explain how stock profiles and non calibrated workflow can damage a printer with 3rd party inks.
I'll wait.
A printer sitting idle with 3rd party ink in the lines is not what I was referring to, though that could be an issue of its own.
What I meant was, a low volume shop that doesn't run their printer constantly is probably not going to justify the cost of colour profiling their own system. They're more than likely going to be using canned profiles. Then if that low volume shop decides to save a few bucks and switch to 3rd party inks, the moderate difficulties they've had in the past with colour matching turns into a complete nightmare.
See above. I wasn't meaning to imply that a non calibrated workflow would damage the printer, just that 3rd party inks would make a non calibrated workflow even more of a nightmare with colour matching.
