There are shops that do what is called UV powdercoating.  It is much the same process but uses UV light to cure the powdercoat.  Much shorter duration and much lower heat.  This gives you the ability to powder coat wood, plastic, certain kinds of rubber and most likely ACM.  You would have to find a shop that does it and probably send them a sample.  But it is possible.
