Need Help Problem Connecting Sc500 To Laptop Via Parallel To Usb Cable
Red/Black86
hi guys im currently using my sc500 with the old lpt port parallel cable to an old xp laptop using flexi 8.6.
now this laptop is old and slow and i would like to use the printer with my newer laptop.
i bought a parallel to usb cable to connect everything up but for some reason i cant get it to work.
new laptop is running windows 10 pro.
the cable adapter i bought was from ebay.
would anyone have any suggestions as to how i would get it to work.
do i need an sc500 driver?
also when i send the file to print in flexi it will rip and go to print and wake the printer up but thats it.
hope someone can help.
cheers
Ken
Try selecting one of the COM ports instead of USB or LPT. For some reason that has worked for me. Can't tell you why though.
Red/Black86
Thanks for your help but I don't seem to have any com port. Only lpt 1-3, usb_printer_0, tcp/ip, lpr, ftp and file.
The fact that usb_printer_0 shows up means that either you have another printer hooked up to the computer or it is seeing the SC500. What does the screen say when it wakes up?
Red/Black86
No other printer attached just the the SC500. When it wakes up the screen just says "now waking up" and afterwards it's just says what print setting it's on and the length of the media.
Red/Black86
this is the event log, if it makes any sense to you.
Level Date and Time Source Event ID Task Category
Information 20/02/2017 14:16:05 Microsoft-Windows-Kernel-PnP 410 None "Device USBPRINT\UnknownPrinter\7&2db3d438&0&USB002 was started.
Driver Name: usbprint.inf
Class Guid: {36FC9E60-C465-11CF-8056-444553540000}
Service:
Lower Filters:
Upper Filters: "
Information 20/02/2017 14:16:05 Microsoft-Windows-Kernel-PnP 400 None "Device USBPRINT\UnknownPrinter\7&2db3d438&0&USB002 was configured.
Driver Date: 06/21/2006
Driver Version: 10.0.14393.0
Driver Provider: Microsoft
Driver Section: NO_DRV.NT
Driver Rank: 0xFF0000
Matching Device Id: USBPRINT\UnknownPrinter
Outranked Drivers:
Device Updated: false
Parent Device: USB\VID_067B&PID_2305\6&35540d01&0&3"
Error 20/02/2017 14:16:05 Microsoft-Windows-Kernel-PnP 441 None "Device USBPRINT\UnknownPrinter\7&2db3d438&0&USB002 could not be migrated.
Last Device Instance Id: USB\VID_0930&PID_6545\00241D8B55E5B02179972853
Location Path:
Migration Rank: 0xF000FFFFFFFFF132
Present: false
Status: 0xC0000719"
I'm willing to bet it's the cable. Even though they all seem the same, not all brands work with these machines for some reason. I have used the Belkin brand before with this exact setup and it worked. Maybe someone else has an idea. As far as I know, there really isn't a specific driver for that machine. I
Red/Black86
Would you have an exact name of the Belkin cable you used??
Red/Black86
Would this work?? USB Parallel Printer Adapter
