I'm brand new to the sign making biz so please go easy on me.
We just got a Roland VersaCamm VP-300 and a roll of Orajet 3651G and some other sample material which is I believe 3165G. I am doing a small job that is text only about 3/4 inch in height (Print +Cut) and having a hard time weeding the letters. When I peel the material the letters come right up with it. Test cut works at about 130gf, however the job doesn't.
-Tried a new blade (both 60 and 45)
-Tried Printing and leaving it for an hour then cutting
-Changed the blade force from 80 - 180 (and all in between)
-Tried job with cut only
-exposed more blade
-exposed less blade
-Using proper profile(s)
When I look close at the cut and seperate it slowly it looks like there is a thin membrane of adhesive that is holding the text to the material but there are score marks on the backing so it's confusing. Sometimes I can pick at the text before weeding and a section of the backing will come up with it.
Has anyone had similar problems? Should I use different material for small text like that? Any suggestions for material?
Like I said it's new to me and I've spent hours on the phone with the tech guys with no solution.
help!!
-exposed more blade
-exposed less blade
help!!
