Hello from sweden! (Sorry for bad English)
We have some problem when we are routing aluminium sheets with full bleed print.
The flatbed we use is Oce 550xt and 360GT both with 257ink.
We use aluminium sheets with white 0500 paint. aluminium thickness is 1.5mm 1mm and 0.7mm
Router Multicam (3000series i think)
The problem is that it comes out flaky and the laminate is loose around the edge. It looks like crap.
We have started to clean the sheets with silicone remover and the inks adhesive is good but it can't handle the force from the router.
It feels like we have tried everything now and can't get it to work.
High and low Lamp settings. Works better when i go as high as possible. Lamps are pretty new and lamp house is clean.
A lot of different kind of router bits. up/down/neutral cutter. Rpms and federates
We have tried seven different kinds of laminate
It´s no different if we let the print sit to cure for several days before lamination.
When we use dibond it works great. So i now suspect that ours alu- sheets paint is the problem.
Anyone know what kind of paint the dibond panels have!?
We are waiting for the answer from the supplier but they aren't fast.
And yes,I have search the internet for the answer
Here is some usual kind of paint types i believe.
Plastisol
solution acrylic
Polyester Silicone
Polyester
PolyFluoride PVDF
Acrylic Latex
Polyurethane
I hope someone here have had the same issue and beaten it and now are willing to share the secrets
Best regards!
Plastisol
solution acrylic
Polyester Silicone
Polyester
PolyFluoride PVDF
Acrylic Latex
Polyurethane
Best regards!
