Problem with Aurora Graphics
Jpuggy83
Hi,
I am having an issue with the Aurora Graphics "Print Craft Pro Fill Suite". When I use a sign blank, and then use the cut path provided, my Versaworks program does not recognize the cut path, and it shows up on the screen as a solid line. No "marching ants". Am I doing something wrong? Thanks for any help.
-Jonathan
signpainter51
cut marks
What software are running your copy through? I use corel draw. I find that I have to import it first to corel then add an outline to get it to register the cut mark when I export it to roland.
Jpuggy83
Sorry, I am using Illustrator CS2. Even when I create my own cut path instead of the provided one, it still does not work. The cut path works fine
with any other file, the Aurora Graphics files are the only ones causing the problem.
