tampaprinting
Tampa Printing
I need some advice on setting up and running a 55" Drytac cold laminator.
We have no problem with webbing the laminate, but for some reason when we're runnning material, the point where the backing separates from the laminate, gets 'sucked' under the rollers, along with the print, as we're laminating a print. This obviously is no good, and things tend to get kicked around the office since it's usually in the middle of a print and we are wasting a ton of material.
We're using 3m gloss laminate.
We took everything out of the laminator and turn it on without anything on the take up reel or going through the rollers. I noticed that I barely have to touch the take up reel in order for it to stop turning. I'm wondering if this is a sign of the tentioners for the take up reel are no good, and aren't taking the backing up fast enough and therefore the separation point gets taken by the rollers feeding the material.
We purchased the laminator only 4 months ago. I called the place we purchased it from, and truth be told, they were absolutely no help on the phone.
I'm just wondering if it's working properly or if I need to call and get a tech out to repair tomorrow when we open.
Thanks for the help and advice.
