Hi,
I hope somebody can provide some help with this problem. I have an old Dimension 200 router and the Z Axis isn't working properly. It doesn't seem to have the power to lift the head and router anymore. Originally I thought it was the motor gone but I got a new one from the supplier and that doesn't work at all. That is another story. Anyway. I cleaned the ways on the Z axis and looked for any obstructions and it appears to be fine. When you hand crank the head up there is a bit more resistance than going down but that makes sense since gravity is helping. Otherwise it seems to move normally. This happened a while ago but seemed to have fixed itself for a while but has returned and will not go away. I have rebooted the machine of course many times with no difference. The weird thing is when I hold the Z axis motor with my fingers it doesn't seem to have any holding power and I can easily stop it from turning. I did the same thing with the Y axis motor and it has much more power and is much harder to hold still. To be sure I switched the Z and Y axis motors and did the test again and it was the exact same so therefore I don't think it is a motor problem. I think it might be a firmware issue but not sure. Other than the problem with the Z axis the machine works and acts normally. I hope I explained this clear enough.
I hope you guys can shed some light on this for me because I am not sure what to do next.
