Problem with my SP300V
Discussion in 'Roland' started by acs9871, Nov 1, 2009.
  1. acs9871
    acs9871 New Member
    9
    Mar 31, 2009
    Maryland
    After doing alot of searching on the forum I cannot seem to find a post with this problem I am having.
    About a month ago, my printer started doing this spray pattern after every black area it printed. It is just the black color and it happens sporadically. One day I was printing and it would make this spray for like 2-3 inches then stop for a couple inches. It would then start doing it again. It then stopped for two whole days and then started up again. It has been doing this off an on for the past month. It isnt noticeable from around two feet away but I see and I do not want to sell anything it does it to.
    I have tried manual cleaning and the cleanings from the control panel and just today I did both of those and right after, I printed something and it was about the worst I have seen it do.
    If anyone has any thoughts or suggestions that might help me I would greatly appreciate it.
    Thanks,
    Adam
  2. JoshLoring
    JoshLoring Very Active Member
    There should be a clear strip that the print head follows if it's any similar to my printer.
    We print soo much that that strip gets dirty. If it appears black you need to clean it with swab and water only.
    That strip tells the head where it's at and if it's dirty the printer gets confused.
  3. JoshLoring
    Lift front and look up above over material area... Strip is there.
  4. Gene@mpls
    Gene@mpls Very Active Member
    2,016
    92
    48
    Jun 17, 2003
    Blaine, Mn
    If this is a ghost like or faint pattern after a black printed object. I would look
    at static electric buildup- it is getting dry inside here (Mn) this time of year
    and I need to get out the humidifiers.
  5. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    do a search for ink overspray..there are a few threads about it...one thing mentioned is banner thread sticking to heads...
  6. acs9871
    acs9871 New Member
    9
    Mar 31, 2009
    Maryland
    Thank you for all the suggestions...I think it is a static problem and I am not really sure how to deal with it. I had the humidifier here going but that didnt seem to help so I am not really sure on how to get it to stop.
    I read something about making a ground to some other metal and then a piece touching the vinyl but it was pretty vague. If anyone has something like that and would explain it a little better I would appreciate it.
  7. MachServTech
    MachServTech Very Active Member
    1,236
    7
    38
    Sep 19, 2008
    North Carolina
    Three things:
    Clean your encoder with a very mild cleaning solution (no solvent)
    Clean the bottom of your printhead with solvent and make sure your caps are clean.
    Make sure that your carriage height is set for the low position unless you are using thick or unruly banner material. (this can get rid of most over-spray resulting from static or other causes)
  8. astro8
    astro8 Active Member
    778
    17
    18
    May 23, 2009
    Sydney, Australia
    Is it on carpet?
    Had a Mimaki on carpet and everytime you touched it you'd get a shock.
    Black overspray was ridiculous until we moved it off the carpet.
  9. acs9871
    acs9871 New Member
    9
    Mar 31, 2009
    Maryland
    I actually got a tech out today and it seems that after all I tried it turned out to be a defective print head he said. I only had that one in there for 5 months so it looks like its all better now. Thanks again for all your guys help
  10. Pacific Coast Sign
    Pacific Coast Sign Active Member
    548
    1
    18
    Jun 19, 2008
    Portland, OR
    ps; you clean the encoder strip with alcohol only..water does not clean the mild solvent ink from the strip. Do NOT use cleaning solvent.
  11. MachServTech
    1,236
    7
    38
    Sep 19, 2008
    North Carolina
    you say "alcohol" and somebody gonna use denatured and wipe the tics right off. you are correct, water alone wont do the job either
  12. SE SignSupply
    SE SignSupply Member
    334
    3
    18
    Nov 13, 2006
    Apex, NC
    I vote BAN-STICK! :noway:
