No Name
Hi all,
my Rockhopper will not print black as it should.
I know that the first thing is to make sure that the print heads are clean and all the nozzles work as they should (well, the black is still 85%). That´s been done.
Dampers seem to be ok, but the black is about half and the others are full. Why?
I disconnected the black damper and it seems there was air in the piping so i took a serenge and carefully sucked the ink through the piping to the serenge,
pumped carefully the ink to the damper and connected it.
After this printing went on pretty good until black started to disappear, 15 inches later no black at all. And the damper is EMPTY!
Is there some sort of a pump (must be) near the cartridge that pumps the ink. Could that be the problem?
Any / all ideas are welcomed.
