Problem with take up roll
Discussion in 'Epson' started by evie, Sep 21, 2012.
  1. evie
    evie Member
    137
    Jun 26, 2010
    riverside ca
  2. mudmedia
    mudmedia Active Member
    507
    Enable auto take up reel on the led panel on the printer. I believe its under printer setup. Normally mine does that when auto take up reel is disabled.
  3. evie
    evie Member
    137
    Jun 26, 2010
    riverside ca
    Thanks, i'll try that
  4. evie
    evie Member
    137
    Jun 26, 2010
    riverside ca
    This worked, but the only problem is now the media won't let me reverse it when i push the up arrow. I am assuming that by having the take up reel enabled, i am losing the ability to reverse the media? Can I have it enabled, but still manually reverse the media when needed? Thanks
  5. MikeD
    MikeD Active Member
    594
    Not sure about your particular printer, but our Mimaki printers have a switch on the motor that has 3 settings; off, forward and reverse.
    We also made one for another piece of equipment that is On/Off only, but has a torque limiter. If yours does, you could loosen it up all the way when you need to reverse.
    Good Luck!
  6. mudmedia
    507
    evie you cannot use the reverse button on the lcd panel. its a design flaw in the printer...terrible design
