Hello Everybody,
I have run into a bit of a problem and will try to explain the best I can. I am working on a large box truck wrap for our company's paper supplier.
Our printer has been having terrible problems printing solids and is under an active call with Roland and no progress has been made. (*not why I'm here)
The paper company had the wrap printed for me at their headquarters with a Mimaki UV printer on Avery MPI1105 SuperCast EZRS . I am only familiar with Roland Eco-Solvent prints and this is my first time working with UV. They did not have a laminator, so they sent the printed wrap to me for lamination (Avery DOL1460Z) and installation.
I have a pretty low quality laminator to work with myself (employee not owner). After laminating the first print, I noticed anywhere I touched the material left a permanent fingerprint or pressure marks. It appears to have left a lot of air underneath the laminate which I assumed was too light of pressure from the laminator. The laminator we have here, has no form of pressure adjustments.
Our print equipment supplier is nearby, and had a floor model of an Emblem Expert 140C Laminator. They agreed to let me demo the laminator by having me run this job through their floor model. The heavier pressure I was able to apply was much better than my first attempt. However, you could still see faint finger prints and marks anywhere the print is touched. The fingerprints can't be squeegeed or cleaned away that I can tell.
The second printer was not heat assisted, and I am thinking that heat assistance is necessary for UV printed panels. Just trying to figure out what is going on here and the best solution.
TL;DR I'm getting fingerprints anywhere I touch the media, after laminating UV printed panels.
*The fingerprints are from touching the laminated panel. Not there before laminating. Any pressure applied post lamination makes a mark, and can't seem to squeegee or roller them away.
