problems sending a .pdf
i'm having major issues sending clients a .pdf. i'm using cs3 and ps4. i'm saving in illy as an .eps, then saving it also as a .pdf. but when i send it to clients its blank! it shows there is a file attatched as it has kb. i also tried saving it via ps and saving again as a .pdf, this time though, its very pixalated when viewed and if you change the view option so you can see the line art it is blank.
so..............what am i doing wrong?
John Butto
When you save it in Illustrator as a .pdf also check to see preview and it will pop up after you save it with a new window in Acrobat showing you how it looks.
ok, so i saved it again as a .pdf............and turned on the review after saving, and it comes up blank! i have no idea why it will not show up to view it! really stumped on this!
jc1cell
Make sure your artboard is set to the right size. At times I work with stuff outside of it and when I save as pdf, get a blank file.
jc
***Edit
John Beat me to it while I was writing.
