Problems with cutting vinyl . . .
Discussion in 'Roland' started by Replicator, Mar 16, 2013.
  1. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    I'm having issues lately cutting vinyl on my Roland CX-300.
    It seems to have started after I cut some of AirArtGirl's Thermo-Flex vinyl on the machine.
    I have changed both the blade carriage and the blade and still I get stepped cuts as seen (badly) in the pictures attached.
    I'm have to go over certain lines with an exacto blade to cut the staggered lines, and it always seems to be on long straight lines in either direction.
    Any help or past experience with this issue would be greatly appreciated.
  2. Replicator
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    A couple of AAG's machines cut the same way and all she cuts is Therm-flex and other garment vinyl's . . .
    The cutting strip is NEW as well !!!!!
  3. Replicator
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    Here's a better example of the vinyl cut lines before weeding . . .
  4. OldPaint
    OldPaint Major Contributor
    i would check the power to the solinoid on the blade. looks like its on/off power and its a set pattern. loose wire, check the strip that connects the cutting head to the main plotter.
    you have to remove the top to see that.
  5. Bigdawg
    Bigdawg Just Me
    7,459
    133
    63
    Jun 8, 2005
    Sunny Florida
    Are you sure you didn't accidentally turn on perf cut????
    Edited: forgot -that's cutting master on the graphtec. But I swear that's what it looks like!
  6. Border
    Border Very Active Member
    2,657
    3
    38
    Feb 8, 2007
    Minnesota
    I don't see any photos here. Did I get banned from that or sumpin'???
    I feel so left out
  7. signage
    signage Major Contributor
    9,414
    57
    48
    Oct 5, 2005
    Penn
    I'm having the same problem. I can see other photos just not the ones in this post.
  8. SignosaurusRex
    SignosaurusRex Major Contributor
    8,466
    440
    83
    Mar 7, 2007
    Washington State
    A bizarre one for sure Rep. Only happening on looooong straight lines in either direction. Hmmmm. I can't imagine it being a solenoid going bad...but anything is possible.
  9. Fred Weiss
    Fred Weiss Merchant Member
    20,470
    368
    83
    Sep 11, 2003
    Olympia, WA
    This has been reported before and it has something undetermined wrong in some browser with showing images that are linked from the poster's profile albums. There's nothing wrong with the images.
    I have replaced the images by uploading them directly to each post.
  10. Fred Weiss
    20,470
    368
    83
    Sep 11, 2003
    Olympia, WA
    The problem with the images not appearing is that the OP had uploaded them to a profile album he had setup as "private" and then linked them to his posts. As a result, the only members that could see them were those who are on his Buddy List.
  11. Mosh
    Mosh Major Contributor
    5,807
    41
    48
    Oct 19, 2009
    Nerbaska
    Slow the speed down a bit, I have the same issue on smaller copy/logos. Once you get the speed and downforce right that stuff should cut like a dream, and weed good too, the backing is sticky so if you pull something up it is easy to stick back down.
    Termoflex is hard to cut small stuff, not sure how big you are going, anything under 3/4" is a PITA, but do-able..just not 50 times you will pull your hair out.
  12. Border
    2,657
    3
    38
    Feb 8, 2007
    Minnesota
    Well that explains it. I know Marc can't stand me!
  13. Replicator
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    Sorry everyone for the photo cluster_fu, but I had know idea the album was set to private....
    Border, you're the best . . . NO, Really
