Procedures for extended down time
D3D
Haven't seen much activity lately and I assume COVID has a lot of machines idling, how are people keeping their machines running well during times of little/no use? I assume it varies based on the machine but I am wondering if printing something daily via automation is a recommended procedure?
AlsEU
It depends on the machine, as you wrote, but for example flatbeds from OCE/Fuji may stay powered for a long time without switching off. Special procedures are required when the machine should be switched off for a long time (more than two weeks).
  • Agree
Reactions: D3D
SignMeUpGraphics
Super Active Member
I've left my Oce on and unused for ~4 weeks in the past during holiday periods.
Just made for a longer cleaning time upon return (1.5 hours instead of 15 minutes), but CMKY always recovers nozzles after 1-2 purges maximum. It's the white that takes all the time to get going again due to the huge size of the TiO2 particles.
Our machine appears to be pretty resilient. Hopefully others will behave in the same way.
  • Agree
Reactions: D3D
zspace
The best thing to do for a UV flatbed is keep the heads full of ink. That usually requires compressed air. Some machines have on board compressors others use air from a shop compressor. Make sure the compressor stays on.
  • Agree
Reactions: D3D
