Profiles and Flexi
Discussion in 'Flexi' started by PMG, Aug 27, 2007.
  1. PMG
    PMG Very Active Member
    2,453
    When you save art work in flexi 8 does the rip profiles save within the file as well,the reason i ask this is i changed profiles for some other work and went back to a earlier job and and did not change the profile back to the original profile and a window popped up asking if i wanted to use rip profile or the PM profile. I also changed the Ink limits with in the same profile,and when i send to rip the file it noticed the Ink limit change from the original file .
  2. Mike Paul
    Mike Paul Major Contributor
    5,438
    8
    38
    Dec 30, 2003
    NJ
    Yes you can set your preferences up to save your settings.
  3. PMG
    2,453
    Thanks Mike,i just reinstalled Flex and never seen that box pop up before,i found the settings to change that to always use rip or Pm profiles!! Thanks
