CSOCSO
Lately I have problem with printing> laminating> then cutting. Whatever I try the rear crop marks are off the plastic line.
Here is how I do it:
When I print I load the material nice and straight then do a sheetcut so its easier to realign the material when I need to cut.
Print as usual
Laminate then trim off any excess overlam off the edge of the media ( without cutting in to the media)
Then I load the media back in to the printer. I have two roller outside of the cropmarks and I also use the removable roller. I align the front of the media straight with the plastic cut strip then lock the machine. The head will scan the rollers and moves the material forward. Usually I need to feed the media backward with the buttons then hit base point when crop marks are right on top of the plastic strip.
On the machine I change the settings to cut only.
Printer finds 2 front marks without any problem. Then moves to the rear marks. 3rd mark is a little bit off and the last one is usually half an inch away from the strip. Doesn't matter how much I try to cheat with putting the material in crooked the 4th crop mark will never land on the right place. The material never wanders away a lot. Just enough so the machine would never find the last marks.
fyi: If i need to print the media does not wander away from the rollers. I can easily print two side of a sprinter ( around 40feet i guess) without refeeding the media. [ No I'm not trying to print and cut 40feet of material....]
Technician also told me the outside rollers have an angle and the little black mark on the roller should face out.
Is there any calibration for this??? Or how do I manually tell the machine where is the mark?
Every print and cut comes out bad.
Print as usual
