Protective Coating on Boat Graphics??
Brandon708
Hi everyone,
I did some boat graphics (not a wrap, just cut vinyl) for a buddy of mine. I used Avery A9 and A high performance 3M Silver.
He had a guy off the old graphics also he brought it down to the paint by taking off the part of the gel coat or clear what ever its called on a boat.
My question is it safe to put a wax or 3M Hand Polish or glaze coat over the vinyl. He needs to do this to the whole boat.
I really want this vinyl to be protected and last on his boat. Is there any advice you can give me on protecting the vinyl.
Thanks,
Brandon
John Butto
gel coat
If it is a fiberglass boat the gelcoat is the top layer over the fiberglass and there will be no paint involved. The gelcoat is the color, gelcoat is a polyester two part mixture of hardener and gel with color mixed in. If you want to do the whole boat with a clear you use use a paint like AwlGrip which can either be sprayed (best method) or they make an additive to be brushed on. It can be sprayed over vinyl letters.
Billct2
It is fine to wax over the graphics. I recommend it on all signs & vehicle lettering.
The problem arise if they use a buffing machine too aggresively or a polish compound to clean the hull. You can do a real premium job by cutting a clear vinyl overlay slightly larger than the letters.
Brandon708
okay.
What i mean is that the boat needs something like wax or a polish because it was stripped of its shine. So would it be okay to use Polish or Wax over the letter. I guess this is a Yes.
rob6894
Yes I do a good amount of boats and not all with cast actually I have a fair amount I have done with iter and never use lam unless it is a printed job. As billct2 said you can wax over it without a problem, I just tell my customers to just wax over the lettering by hand .
