PS .jpeg Conversion Problem
RedlineMan
Howdy;
I have a multi-layer PSD file that I am trying to convert to a JPEG. Usually this is not a problem, but something is preventing me from doing it with this particular file. The usual routine does not offer the JPEG format.
> Flatten Image > File > Save as > Choose Format... but no JPEG option.
I'm confused...
RedlineMan
Hey;
It's RGB. I have had problems in the past but have always gotten around them one way or another. This one won't go. I'll attach it. See if you can spot the problem.
  • CNYPCAcolor07.psd
RobGF
Well my PhotoShop saved it as a JPG no problem without doing anything special. The process did flatten it but that's to be expected. Did you try doing a manual flattening of your layers before attempting to save as a JPG?
Good luck.
Edit: I reread that you did flatten... All I can tell you is that MY CS (version 8) had no problem with the task.
mark in tx
this saved without a problem for me.
Jackpine
Hey;
I saved them as a jpeg and a bmp and imported into CorelX3 without a problem.
RedlineMan
Hmmm...
Thanks Folks! I'm a self-sort-of-taught PS hack. Still using PS5. Not sure why that would matter, but it appears it does. I sure would like to know why it would not save in case it happens again.
:help:
