We have a city that requires push-through letters that have at least a 3/4" reveal and a client that wants the entire face to be lit. The cabinet is essentially a 5' diameter circle. Our concern is the polycarb face not being able to withstand the weight of the push-through letters. Anyone have any advice? We had looked at thermoforming but the lead time was too long and most vendors were only able to do 1/2" off the face.
As jburton asked, what is a 3/4-inch "reveal" on a push-thru letter? Sounds like they want the letters to
protrude three quarters. Unless they are specifying a 3/4-inch lip on the back of the letters.
If the letters must protrude 3/4-inch, then the final thickness of the letters will be close to one inch when the lip is included, right? I'm not sure I would trust an acrylic push-thru letter of that thickness staying adhered to the back of a routered polycarbonate face. Better for both the letters and the face to be the same plastic, and my choice for the face would probably be acrylic, 1/4-inch in thickness. The acrylic letters will bond better to an acrylic face. Why polycarbonate if it's not required?
Polycarbonate flexes more, as it is a softer plastic, and the thick push-thrus, which will
not flex, may have a problem staying adhered whenever the face flexes.
And will the lip of the letters not be visible behind the translucent face? Maybe if the face is not too light in color, then the lips of the letters may not be a problem.
A thermoformed face would look good, but then the letters would no longer be push-thru. They would just be embossed (raised), as part of the face. Your client may not know what "push-thru" means, but surely the city does.
I would communicate serious reservations to the client. I would specifically warn the client that the adhesion of the letters might fail, not so much because the letters are too heavy, but because they are so thick and heavy. The whole idea seems "iffy" to me.
Good luck! And I hope you post what you end up doing.
Brad in Kansas City
