Reaction GFX
I don't do a lot of installs, but I have a client looking to mount some 4x8 panels of 12mm PVC to a concrete block interior wall. I was thinking French cleat, also made of 12mm PVC. Do you think I need a cleat top and bottom or would just a top cleat and a bottom spacer be sufficient? How, exactly, would you recommend mounting the panel side of the cleat to the panel itself, considering it is only 12mm thick? I recall using pins and some special PVC glue to bond two single-sided routered sign shapes together once to create a double-sided blank and it worked quite well, but it also wasn't very heavy and it was hung with screw eyes and s-hooks, so the glue holding the two panels together really wasn't supporting any of the weight. Maybe VHB tape instead of glue? The last thing I want is for the cleat to detach from the panels and the panels to come crashing down, potentially hurting someone.
Any advice is appreciated!
