Q130 Contour Cutting Problems
Discussion in 'Graphtec' started by All Star Sign Shop, Oct 15, 2018.
  1. All Star Sign Shop
    All Star Sign Shop New Member
    4
    Oct 11, 2018
    Oklahoma
    My machine is old, I get it. It's progressively gotten worse with contour cutting. VERY inaccurate. I did a factory reset and it's still bad. My cross hair tests come out perfect. Adjusting the Axis Origin won't help either. It's usually cutting high and to the left on the right side of media, and low and to the right on the left side of the media. So adjusting it wouldn't help. Has anyone experienced this?
  2. bannertime
    bannertime Very Active Member
    2,160
    505
    113
    Sep 8, 2016
    No
    I have not experienced this. First thing I'd check is if the sensor lens is clean. Next would be making sure all the settings match up. i.e. the marks are the same on the computer and what the machine expects, mark size, etc. After that. Not sure.
  3. All Star Sign Shop
    4
    Oct 11, 2018
    Oklahoma
    Yep. Have done all of those things. Thank You though!
  4. bannertime
    2,160
    505
    113
    Sep 8, 2016
    No
    Have you watched to make sure it's scanning the marks and it's not picking something else up? We had a job that would not work until we realized it was trying to read the artwork instead of the mark. Also, there was a beam of light coming through a window that was hitting the material just right to mess up how it read the mark. I didn't find it until I watched it scan each mark.
  5. eahicks
    eahicks Magna Cum Laude - School of Hard Knocks
    2,500
    356
    83
    Apr 17, 2012
    DALLAS, TEXAS
    Q54 here and we have issues a lot. And I use the BombSight alignment nearly exclusively. So I don't have issues with the machine not reading the reg marks, I just have issues of accuracy in cutting no matter how meticulous I am with aligning myself. What is weird is that I usually have to shut off the plotter and restart before I cut a job. If I go from one job to the other without restarting, the next one I set up and cut will be off. Sometimes a little, sometimes a lot. And we do so much that even being 1-2mm off will ruin the decal (usually having a border with some white space around it). Anything relatively large is usually ok and not too noticeable if it's off. But we do lots and lots of 2", 3" type decals and we've had entire runs be trashed due to the plotter errors.
    Guess it's time to look into a new plotter.
    • Like Like x 1
  6. All Star Sign Shop
    4
    Oct 11, 2018
    Oklahoma
  7. All Star Sign Shop
    4
    Oct 11, 2018
    Oklahoma
    Yea I've checked those things. Reads all marks perfectly.
