Question about scan motor compatibility
Msrae
Rae
I have recently had to replace the scan motor on my CJ-540. I got the scan motor with the part# 7811909010. Apparently this is for the FJ, but from what I can tell when doing a search for the scan motor, they are compatible. Can anyone tell me if this is the case? Can I use a scan motor for an FJ-540 in the CJ-540?
I have installed the motor, did all the steps to reset and it gave me some issues. I have also used the right, up, left arrow keys and power (can't remember right now what the name of that mode is, since I am not at the machine) and get as far as the initialize then I get a "unrecoverable limit sensor" error. I have tried this at least 6 times now, and still get the same error. I have tried cleaning the sensor, etc. The cut head will NOT release from the print carriage.
I am trying to decide if perhaps the scan motor could be the culprit or if it really is a bad limit sensor.
HELP! Thanks in advance
Rachel
inkmed
#7811909010 motor compatible to both Fj540 and CJ540.
the sensor error may caused by bad sensor, you can change a new one and test it.
Adam Yang from Inkmed
Msrae
Rae
Thank you for the reply. Yes, I figured it could be the sensor, just wanted to rule out the motor first since I had just replaced it and this error was not showing prior to this point.
Do you supply the sensor?
Thank you again.
Rachel
