Question for VersaCamm users
Discussion in 'Roland' started by txsurfer, Feb 27, 2006.
  1. txsurfer
    txsurfer Member
    284
    Oct 29, 2005
    Texas
    I am using the SP-540V, with Max Inks, and VersaWorks.
    I am taking a poll to see what percentage of jobs you print are in the normal mode, and what percentage is in the high quality mode?
    Also do you have a standard that you go by, for example hardhat decals in high quality, outdoor banners in normal quality?
    It seems like we are printing alot of jobs in the High Quality mode?
  2. GregT
    GregT Very Active Member
    I have the SP300V and use very little in the high quality mode. Most everything is normal mode. Thats not to say the I don't use the high quality. The difference comes when the customer wants a difference. just my 2 cents
  3. Barry
    Barry Active Member
    659
    May 6, 2004
    I print vinyl at 720x720 8 pass mode. I get photo quality results and about 64 sq feet per hour speed. With banner I will print 720x360 and get a little more speed.
  4. Drip Dry
    Drip Dry Very Active Member
    1,122
    1
    38
    Aug 11, 2004
    Long island NY
    I use standard mode for most everything
    If I'm doing something like one day golf signs, then I run it in High Speed.
    Unless you look fo it you can't tell the difference.
    I never saw any need to run high quality
    jim
  5. mikesign
    mikesign New Member
    I print most everything at high speed on a 540v from versaworks. Never yet had any complaints. The max inks look alot better at this speed than the reg. ecosol inks did.
  6. Mike Paul
    Mike Paul Major Contributor
    5,438
    8
    38
    Dec 30, 2003
    NJ
    Standard for most everything. H/Q for small detailed logos.
  7. stopngo
    stopngo Member
    136
    95% of everything that we print is at the standard 720x720. Bump up the head speed if you need a little more sq/ft per hour but watch for banding. Otherwise there is very little difference to the common consumer.
