Question on an install technique
Dennis422
Hi guys. For the first time I have to install big 4' tall and 10' wide decals.
It is printed and cut Avery 1005 RSEZ with DOL 1360 laminate. They will be installed on the sides of the box trucks with some rivets.
My question is, use a middle (vertical) or a top (horizontal) hinge?
I will have helper, for cleaning of the surfaces and for getting the decal up and ready for installs. He can help me with holding the transfer tape tight if middle hinge is used.
How would you instal this?
I just installed these today on a friend's snowmobile trailer with 3M IJ180. They were 155" x 30" and I center hinged them and applied them with the use of a helper. Fortunately there were no rivets and it took about a half hour to clean and a half hour to install. I could have done it myself using magnets had it not been an aluminum surface, but regardless, two is better than one in these situations.
Dennis422
This one went pretty easy. With help is no problem.
Luckily, there were no rivets involved. Out of 13 trucks that get these big decals, 10 of them do not have rivets. (Only a few on the back roll up door)
eahicks
Guess I didn't realize it was cut vinyl...in that case you CAN tape a hinge horizontally across the top, then cut vertical strips and lay pieces at a time. This is especially beneficial if you only have one set of hands installing a big graphic. Obviously, this won't work for a large decal, or any cut vinyl with a long horizontal piece in it that can't be cut.
