iSign
The first attachment will be the proof of my final product. I wanted to do most of this sign as a single 3D routed HDU sign, and even got as far as programing (& test running a small sample of) the woven mat background, which is an actual Bamboo product...
...but my client really wants to go with using the bamboo mat itself (second attachment) & he has been informed, and accepted that I can not warranty the life expectancy of the sign as a result. That sort of texture is of common interest around here, so I don't mind the time spent on creating a routing file for it, or the chance to experiment with using the actual product on a sign where the end user has taken on some of the risk for experimentation...
But anyway, now that you have some of the initial background information, the plan at this stage is to use an adhesive & bond the mat to 1/4" acrylic. This will then get a sealer/stain. I will assemble a wood frame, routed like a picture frame from the back to protect & hide the edges of the mat.
Here is where I have some acrylic questions. I plan to bond a lot of acrylic to the stained mat & for this I plan to use liquid nails. If anyone has suggestions, or cautionary information related to this, I'm interested, but i don't have too many concerns with that step...
The steps I'm unsure of is the painting of the acrylic, and the bonding on multiple layers of acrylic. I know the acrylic cement needs to melt raw acrylic, but I also know pre-painting items before bonding means I can spray them, so now i have questions about bonding them, spraying thenm, and rolling paint on the faces.
I think the best plan I can come up with so far (without starting over) is to cement everything together & spray all the bamboo stuff dark green, & then roll on 2 coats of the light green just on the face of the top layer... and for the lettering, bond with acrylic cement, spray the burgundy, & roll on two coats of the imitation gold color.
Now, I am definitely open to feedback on those ideas. The most obvious alternative to me is to forget the acrylic cement, spray all my colors, & then bond with some other adhesive that doesn't mind bonding painted surfaces... which brings me to my paint questions...
I am not a paint expert by any means.. I've rolled 1-shot on panels for many years, & I've also painted small wood or PVC letters with a foam brush... my only spraying experiences are a lifetime of playing with rattle-can spray paints, and a little bit of experience spraying Porter latex with an HVLP gun on HDU...
so, on the all important paint questions, what surface prep might I need for acrylic? Just clean & free of dust, or do i need to scuff it with a 600 grit or steel wool? What paints can people give me feedback on... enamel spray paint? Latex enamel thinned for HVLP? Rolling on 1-shot?
..and of course if I do go with spraying the different colored parts separately, what adhesive can be recommended for bonding the unpainted acrylic backs of letters to the painted acrylic faces of their outlines pieces?
the last round of questions pertains to some of the other unforeseen challenges in the largest batch of acrylic lettering I've ever cut... I used a carpet tape for holding down the acrylic. Some I peeled the paper liner before routing, some not... but in either case, the "sawdust" sticks to the edges where there was tape, because the process of cutting seems to get adhesive on the edges, or mixed in with the sawdust & it doesn't blow off with the compressor like I hoped... so it becomes a bit of a chore to wipe off... anyway, I pretty much have everything cleaned up, but if I wanted to get them even cleaner, I wondered about soaking the letters in something that breaks down that adhesive residue but doesn't hurt the acrylic...
..as for that last question, if the right answer would have been to paint first, mask, then rout, or perhaps to stock some kind of sheet version of 3M VHB tape & have that applied to acrylic before routing... well, go ahead and advise me of any tips and tricks any of you have to offer, even if it means I'm already doing it wrong... it's never too late to learn, and I'm the first to admit I have a lot to learn on my relatively new foray into the world of CNC and to a slightly lesser degree, the world of paint.
The last few attached pics show the acrylic pieces in there slightly sticky sawdust covered state, before peeling paper, or carpet tape... and then the semi complete layout of unpainted pieces (minus the uncut web address) ...and following a quick edit, I've added a photo of the clients old sandblasted sign, which I've never seen in person but copied from this pic...
*EDIT* decided to add another pic because the lighting in my acrylic pieces pic is poor, and I wanted to show that where my layer of leaves overlaps the bamboo stalks, I created a slight outline contour for each leaf section, and welded that to the bamboo stalks, so there are no leaf sections floating unsupported out over the background... just to help give a complete picture of what I'm trying to do...
