Questions on Typograf?
Discussion in 'Fonts and Typography' started by smullen, Aug 7, 2005.
  1. smullen
    smullen Member
    188
    What is the difference between ""Load" and "Install" when you right click on a Font?
    There are both options... Neither seem to install the font...
    Do you have to reboot or close/open your applications, before they'll recognise the new fonts?
  2. Bobby H
    Bobby H Very Active Member
    2,262
    204
    63
    Feb 4, 2005
    Lawton, OK
    What application are you using to install or manage fonts? Also, what operating system are you using?
  3. Fred Weiss
    Fred Weiss Merchant Member
    20,923
    546
    113
    Sep 11, 2003
    Olympia, WA
    Install should bring up a three choice box with a recommended choice of copying the font to the Windows font folder. Load simply makes a virtual version available in your applications without physically installing the font.
    Whether a relaunch of an application before seeing the fonts in your font menu is necessary depends on the application. Adobe Photoshop, for example, sees the new fonts even though it may be already open. So does Adobe Illustrator 10.
