quick ? about tractor
Discussion in 'Newbie Forum' started by RubberDuckyDecals, Oct 17, 2006.
  1. RubberDuckyDecals
    RubberDuckyDecals Member
    28
    so, i ordered non perforated film for my roland gx24 but ordway sent me perforated. Can I still use perforated film and have it feed correctly?
  2. Gino
    Gino Premium Subscriber
    33,109
    2,255
    113
    Jun 7, 2006
    PA
    Probably.
    If the vinyl goes out to the edge no problem at all. If it has the 1/2" cut-away, it might not track very well, as it becomes a little slippery against the backing waxed paper.
  3. giantsfan1951
    giantsfan1951 Member
    148
    i use perfed vinyl all the time in my CX 300 and used it in my PC 900 for years ... no problems
  4. RubberDuckyDecals
    28
    cool, thx guys. the holes are about 1/4in from the edge so I suspect it should be ok. Just wasn't sure if I should be sending this roll back or just dealing with it.
  5. Fred Weiss
    Fred Weiss Merchant Member
    20,534
    402
    83
    Sep 11, 2003
    Olympia, WA
    I think you will find that most vinyl distributors will offer 15" and 30" roll widths in perforated only while 24" and 48" will be offered as non-perforated. This is to accomodate Gerber plotter owners whose plotters will be either 15" or 30".
  6. learned the hard way
    learned the hard way Active Member
    544
    Set your pinch rollers slightly inside the perf lines. If you set the rollers on the perf, it makes a heck of a racket when the machine rolls the vinyl in and out quickly. Also, over time, the rollers will squeeze adhesive through the holes in the vinyl and get it all over your pinch rollers, leaving you with lumpy rollers that have to be cleaned.
  7. RubberDuckyDecals
    28
    ohhh that's a very good suggestion, thx =)
  8. TheSignDepot
    TheSignDepot New Member
    8
    This just happened to me and was driving nutts, I walked by while my cutter was running 15" perf, I asked what the HECK that noise was, I was getting ready to completely tear it apart and check all the gears but this had to be the problem because I've been cutting vinyl all day using 24 inch and not a peep. I really can't believe this came up but greatful it did.
    Happy Cutting
    :beer
  9. Hollywood
    Hollywood Member
    357
    All I use is Per in my CX 300, youll b fine
