Quick question about printing in 360x360 mode
Discussion in 'Mimaki' started by RoCo, Dec 11, 2013.
  1. RoCo
    RoCo Member
    91
    Nov 5, 2008
    I'm running a JV-250SP outfitted for dye sub. We have an annual job where print quality is not really an issue (viewing conditions allow for it), but it's huge, square footage-wise. I decided this year to run it in the fastest mode I can print which is the 360x360, low quality, bidirectional. But the issue I'm having is that the start / stop points on successive passes aren't lining up (about 1/16" stagger). If I print it in unidirectional they line up perfectly, of course, but that doubles your production time. I recently did a print head alignment from the ground up, so I don't think that is the problem, and I couldn't find any alignment checks that addressed this particular issue. Again, it's not the end of the world and I can still run this job in bidirectional with the staggering, but I was wondering if there actually is an adjustment I can make or if "it is what it is," so to speak.
    Thanks for any advice.
  2. P Wagner
    P Wagner Very Active Member
    1,928
    83
    48
    Aug 16, 2006
    San Diego
    Make sure that you are performing a Bi-Directional Alignment Calibration, and not a printhead alignment calibration.
  3. RoCo
    RoCo Member
    91
    Nov 5, 2008
    All of my other speeds / modes line up perfectly from the head alignment I did previously. I've been searching for some kind of strictly "bi-directional alignment" procedure, but have not come across one, yet. Can I go into maintenance section and then specify the 360x360 mode and then perform the bidirectional alignment from there? Maybe I'm missing something else.
    FWIW, I'm using TexPrint RIP (again, dye sub) and I spec the print environment (color profile, fabric, speed, resolution) of the printer when I rip the file.
  4. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    definitely bidi alignment is off
  5. gregwallace
    gregwallace Member
    168
    1
    16
    Feb 14, 2013
    Arkansas
    There are three things that affect bidirectional alignment. Carriage speed (left and right), head height, and the bidirectional setting on your printer. The resolution and pass count wont make any difference. Does your rip software have an adjustable carriage speed setting? Did you change the head height for this job?
    When you say staggered you don't mean that the edge of your print looks like stairs veering off to the left or right do you? That would be an encoder/encoder strip issue.
