Quick question please help ???
Discussion in 'Roland' started by kustom.printing, Apr 9, 2009.
  1. kustom.printing
    kustom.printing Member
    291
    I am trying to cut a circle out of a design in Illustrator, when I test cut it is perfect but the circular designed in Illustrator comes out like this
    I don't know if you can see but it is curving in and out not 100% circular, sometimes it just comes out more oval.
    Other shapes and like I said before the test print are perfect.
    I have the right profile, sheet set up right, everything is pointing to Illustrator, I have the cut contour stroke on 0.25pt.
    I would really appreciate your help.
  2. DRamm76
    DRamm76 Member
    496
    1
    Could be your monitor settings as it may be viewed on way but if your monitor settings are set widescreen or more "stretched" it may not be viewed as designed.
    Try to recreate a different circle and you may already know this but hold Shift down when enlarging it to make it fully proportional. Hope that helps. Email me if you have any questions. Or you can send me the file and I can check it out here on my end
  3. ProColorGraphics
    ProColorGraphics Very Active Member
    1,457
    89
    48
    Apr 1, 2009
    Minnesota
    If it is the little edge on the left side of the picture, then it probably the blade offset setting under the cutting adjustment on the printer. Try adjusting that and see what happens.
