Radius Cutter
Conor Knoxx
anyone have any recommendations / experience for a tool to cut radius corners on 3mm dibond/alupanel and maybe .060 gauge aluminum?
Nothing too fancy or high volume... just to make it a little nicer / faster than sanding or filing.
Thanks,
Conor
Mosh
I have the heavier one, I have several dies, the slotted hole punch gets used as much as the corner rounder one.
Grizzly
It’s all about your print!
Corner Smashing?
I'm looking at getting a accucutter cornermate plus and wondering if someone can give some feedback.
I'm hoping that we can cut down on bit time by cutting on a table saw and then punchng the corner.
We route our blanks first and then print and clear coat through a roll system.
I'm wondering if the accucutter smashes the corner in a little.
If this is the case when you run it through a roll coater the edges don't get coated since they are a different thickness.
Jeremy
