Follow the directions on the label just like it says, otherwise it does not work as well. All we use!Thanks everyone for the great info! I'm not trying to cut corners and I'll go with the rapid tac, I've been getting the turtle wax green can stuff which works good but wanted something I could apply quicker than an aeresol can and wanted to make sure there wasn't something else out there that worked just as good for less. Again, appreciate the input from everyone!
Thank you for Vinyl Off info.I hate using a respirator. Rapid tack is top notch, but I switched to a much safer chemical. " Vinyl off reflective remover" . It's biodegradable, got no odor, no resperator needed. It's almost as good as rapid tack.
Walmart sells stuff in the same class as rapid tack called Turtle wax sticker and decal remover. It's a green spray can located in the automotive section. I buy about 20 cans of that a year 5 bucks a can.
It's actually citrus based and not solvent based so it won't harm you.
If you read the MSDS you will see there are petroleum distillates, ether derivatives (1-Propoxy-2-propanol) and alcohols in the ingredient list.It's actually citrus based and not solvent based so it won't harm you.
I'd prefer not to have to remove the adhesive. If I flash the old vinyl with a heat gun, most of the adhesive seems to come off with the vinyl. If I don't, like today's, I seem to have a lot more residue left.
LOL! Don't inhale. Take note of this. I got a big breath of it a few times. It will make your mouth, tongue, throat, etc go Numb for 30 minutes. Not real pleasant.
