Raster Image countour cut
ssfirme
Ok so i have a raster image and i put a Roland versa coutour cut( the pink contour cut). Then i save as EPS and i open the file in versaworks, but it only prints and does not cut it, how can i cut a raster image?
fresh
i don't have a roland, so i'm not sure if its the same thing... but usually you need a vector outline in addition to the raster image in order to do a print/cut
player
Assuming the cut line is present, there is a setting in Versaworks in the Settings ---> Cut Controls tab that allows you to choose print/cut.
CanuckSigns
If you did the cut line properly, when you bring the file into versaworks there should be a red flashing "marching ants" line when you click the settings button, if you don't see that, something went wrong with the cut line (wrong thickness, not a spot colour etc.)
hope this helps
splizaat
You need to select all layers except the cut contour layer (in illustrator) and flatten transparencies. Then save and bring it back into versaworks.
