RASTERLINK 6 Need help with color adjustment
Discussion in 'RIP Software & Color Management' started by Master's Touch, Jan 28, 2019.
  1. Master's Touch
    Master's Touch Member
    261
    4
    18
    Mar 10, 2005
    Conway
    New to Rasterlink. I have searched all over and I can't figure out how to adjust color inside the RIP. On the tab for adding or removing color, the controls are grayed out. Help? I am specifically trying to get a warm grey to be a cool gray, and editing it the eps file is not appearing to make a difference.
  2. Solventinkjet
    Solventinkjet DIY Printer Fixing Guide
    4,434
    845
    113
    Aug 2, 2011
    Denver, CO
    They trick you with this. Where it says "Standard" delete that and type in a new name and then hit the + button. That will create a new color adjustment file and then you should be able to adjust as necessary.
    • Like Like x 3
  3. Boobankee
    Boobankee New Member
    3
    Feb 1, 2013
    Saskatoon, Canada
    OMG I clicking on everything to get the density to change! Thanks for the post.
