Really, really OLD vinyl removal product/technique recommendations
Discussion in 'General Signmaking Topics' started by Joe Diaz, Aug 27, 2018.
  1. Joe Diaz
    Joe Diaz Very Active Member
    This isn't in my wheelhouse, so suggestions would be greatly appreciated. I've got a sports car here that I want to take extra care with. It has 10 inch wide silver metallic rally stripes that have been on there sunbathing for several years longer than they should. The stuff is all cracked and weathered and instead of coming off in a few pieces, will most likely come off in a few million little pieces. I'm wondering if any of you have had good luck with a product that expedites this process?
  2. Texas_Signmaker
    Texas_Signmaker Very Active Signmaker
    4,927
    1,828
    113
    Oct 21, 2016
    Frisco, TX
    Eraser wheel, but I'm sure it will be a different color under that vinyl
    • Agree Agree x 1
  3. Gino
    Gino Premium Subscriber
    34,211
    2,575
    113
    Jun 7, 2006
    PA
    Zapper, but as mentioned it will be a different sheen to it. Probably be very noticeable.
  4. Joe Diaz
    I was thinking about using the wheels as a last resort. I don't have a lot of experience with one, so I guess I'm afraid of marring up the paint. But if there isn't some sort of chemical solution, that might be the way I go.
  5. Gino
    34,211
    2,575
    113
    Jun 7, 2006
    PA
    If you are doing metal, any kinda metal, it will not mar up the paint job. After the vinyl and rubber debris are wiped clean, just hit it with alcohol and it will look like nothing was ever there, except it will be bright and shiny. We use them all the time and nothing has ever gone wrong, except when we hit a rear bumper, that was not metal. Oops.
  6. AKwrapguy
    AKwrapguy Active Member
    969
    281
    63
    Sep 6, 2014
    Anchorage, AK
    Heat gun and time... Rapid remover to remove adhesive. Depending on how long the stripe has been on there and how much UV damage is on the original paint, there's good sign that you will see difference under the stripe. As far as the wheel goes, I have a guy here that used them all the time. Just take your time, pay attention to how much pressure you using.
  7. AKwrapguy
    969
    281
    63
    Sep 6, 2014
    Anchorage, AK
    What happened to the bumper?
  8. TimToad
    TimToad Very Active Member
    2,567
    636
    113
    Jun 13, 2013
    CA
    Joe, try VinylOff on a little piece. It seems to work the best on vinyl that is that far gone. Its turns it into a gelatinous goo, but at least you can then get most of it off with a soft squeegee or plastic razor blades. After that, I'd go at it with Rapid Remover.
    • Like Like x 1
  9. 2B
    2B Very Active Member
    3,060
    397
    83
    May 5, 2011
    TX
    other options
    • clothe/wallpaper steamer
    • high heat pressure washer
