Recurrent problem with Roland VS-300, nozzles go missing when doing cleaning. Come back after head soak... HELP!
psychopat
Hi everyone, I really need to pick your brain regarding this issue.
I have a Roland VS-300 and the head was replaced a few years ago. Im running genuine ink, all original parts.
A few weeks ago, I was missing some yellow nozzles. Did an overnight head soak and they came back. Then on my next batch the following week, the yellow nozzles were missing again, as well as some of the magenta.
Did another head soak, they came back but there's a slight distortion in the yellow and magenta. Also a tiny bit of blue in the yellow. Any how as soon as I do any cleaning, normal, medium etc. I lose the same nozzles again.
I changed the wiper, felt, cap top, new fresh ink, renew ink, Im at 5 head soaks and its always the same cycle. The nozzles are back, then after some cleaning or just the printer automatic cleaning I lose them again.
Im not sure also what cause that swirl / distortion also what would make the nozzle go away again. They are not clogged because after the head soak everything is ok.
What happens when a normal, medium or powerful cleaning is done? Im trying to figure out the source of the problem and what could cause that.
Running out of idea and trying to at least to recover my yellow and magenta.
Cant afford a new print head right now :( Any ideas or help would be appreciated, I had this printer for over a decade and never had an issue like this.
Thank you!
Zoogee World
If they're coming back, I wouldn't say it's the print head, does sound a bit like ink starvation, could be the dampers or might be the cap top not having a good seal. When you lose the nozzles is there still ink in the lines?
psychopat
There's still ink in the lines yes when the nozzles are gone. I already replaced the cap top and that didnt help. I havent tried to replace the dampers yet, I guess I could try that as well. I never replaced dampers in the past, hopefully its not too tricky.
Zoogee World
To be honest, replacing the dampers on that printer, as it is just the one head, is probably one of the most pain in the butt machines to do it on and if the lines aren't cleared out and drip can blow the head. You could try attaching a syringe to one of the lines after the cap top and pinch off the other and see if you can pull ink through, give you an easy way to see if the seal is good on the cap top.
damonCA21
The head itself is ok as it does print fine some of the time. To be honest, pay to get a technician to come out and give the machine a service and replace captops and dampers for OEM Roland ones. The heads are not easy to work on and you can easily cause more damage yourself
psychopat
I checked the flushing adjustments after replacing the cap top and it was aligned properly. I can try to pull ink from the bottom to make sure of the seal.
Even when all the nozzles are missing, I did a CMYK yellow and magenta 12" square and still looks good at high quality which makes me wonder even more whats going on (see pictures)
Unfortunately there are not any tech in my area, closest ones are 3-5 hours away. Seems like a far and expensive trip just to change the dampers, then having to come back again if its the head.
I only ever used OEM Roland parts and ink.
psychopat
I dont understand what could be causing those "curls" in the print test. This isnt an alignment issue, the rest is fine.
Whatever it is, that's where the nozzles go missing after some time. Then they come back if I do a head soak...
I attached the full res print tests.
Zoogee World
That is head damage, looks like there must have been a pretty decent head strike. Sorry, not sure why I didn't see that earlier. Unfortunately a new head would be needed.
psychopat
yikes, I have not noticed any strike. I learned the hard way to never leave media on the machine, sometimes vinyl curls on the side and can strike the head during the automatic cleaning.
Since I replaced the head a few years ago I always make sure to remove any media loaded on the printer to be safe.
Basically the print test looked like this:
Then at my next batch 1-2 weeks later, that's when the yellow was missing nozzles.
Then while trying to resolve the yellow, the magenta and curling started.
Someone on a Facebook group recommended Digiprint for a new head and kit. Is that a recommended source for genuine Roland parts? Its cheaper than what I can find here, my last head swap cost nearly 4K CAD.
Gotta make an hard decision, if its something worth fixing or maybe buying a newer model. I can only fit a 30"ish printer and already got 2 laminators that same size and all my gear.
My options seems to be:
Mimaki CJV150-75 32"
Roland SG-300
Roland SG2-300
Roland SG3-300
I think the CJV150 use the same DX7 head right? I was hoping to get a model where if I have an issue with black, I can change a single head and not the entire all in out unit like the DX7 which is pricy.
Heard the SG-300 initially had a lot of issues too. Is it still the case?
A Toronto dealer has both of those units available and they would trade in my VS-300.
Or would you recommend the latest SG3 to be more future proof? I really like the features like nozzle issue detection and being able to use the printhead until its last breath. If something like that would have been available on my VS, I could have used it much longer setting only 1x CMYK instead of double as the left colors have no nozzle issues.
Zoogee World
I wouldn't recommend DigiPrint, they sold us a defective head and then wouldn't do anything, this was for our VS-300i, which uses the same head I believe. Unfortunately the heads for these aren't cheap, as it's a 1 head machine. If you do want to continue with a new Roland, I'd recommend the newer SG2 or SG3, stay away from the SG models, they have all those issues you've heard of, the newer models have worked out those kinks for the most part. The VS-300i as a used model might be of interest to you if you can find a decent one around you.
citysignshop
Little consolation; but my VS-540 does the same thing(s).
Frustrating!...replaced almost everything, still does it....and the techs aren't all that good at trouble-shooting anymore, they just replace stuff until they might accidentally 'hit it'.
I'm suspicious that there's a cracked line or fitting somewhere, since they are 10' long, it doesn't show up right away. One more printer headed for the dump! :(
psychopat
Yeah, often seems like it. Im going to order some dampers and see if it helps
I got a few estimates just for a new head, dampers and everything else needed and its almost the price of a newer machine.
Found a Mimaki CJV-150-75 with 30 days of use and brand new head on it. I never used a Mimaki before but it seems a lot more modern feature wise vs my old VS-300. Is that a fairly good machine?
Will update once the new dampers are in. Got my hands on the service manual, wish me luck :)
psychopat
You Still have not mentioned if the dampers have been replaced and with which kind/part #?
Yes, the head joints need to be checked.
ok here's an update regarding this. I bought new dampers, captop, wipers etc. all OEM
I managed to install those bad boys, it was the first time I replaced dampers myself.
I followed the service manual, choke valve off, only difference is I clamped the ink line to limit the spill.
I did one damper at the time, clamped line, pulled out the damper joint, replaced the damper (same exact orientation as before) within the head cover. Then I reinstalled the damper joint.
Then I checked inside the head to make sure none of the old damper o-rings were stuck in there, all looked good. I put the choke valve back and used a syringe to pull the ink to fill up the dampers.
I re-inserted the whole head cover with dampers until they it clicks then re assembled everything.
The service manual said to do a powerful cleaning then a choke cleaning but I figured since I primed the dampers with a syringe its probably just a waste of ink right?
I didn't have any problem at all pulling the ink to the dampers, it came in easily.
So I guess that means the lines are flowing properly from the cartridge to the damper I would assume.
Did some print test and its pretty much exactly as before.
Is it worth to try a choke cleaning, or light choke cleaning? Should I try to pull ink from below (captop)?
By inspecting the "head joints" you meant the damper joints that connect on top? They looked ok and ink pulled easily to the dampers.
I watched videos and saw someone had similar issues and it was de to the choke valve on some of the colors. However since the ink pulled ok, I figured its probably not an issue.
Should I open the panel at the bottom where the ink cartridge are located and swap the ink lines for yellow and magenta to confirm the issue 100%?
I imagine after all this, there's probably a high chance I need a new head. :(
Please let me know if you have any advices.
After doing all the damper stuff, I feel almost confident to swap the head myself. Since the dampers are already new, it should be just a matter of pulling the assembly (head cover) and re inserting it to the new head?
Then entering head rank, then doing a calibration? Anything else needs to be adjusted after replacing a head?
Zoogee World
As mentioned before, unfortunately it's the head, it looks like there was a head crash, it shouldn't be warping like that. It's never fun having to replace a head, especially that one, as it is relatively expensive. Make sure to buy OEM. It's not worth trying one of those cheap ones.
Jim Hancock
Old School Technician
Not sure where you bought your parts, but those prices are ridiculous! I'm presuming those are Canadian dollar amounts, which would mean you paid 2-3 times what you can get the parts for at Solventinkjet.com. I suggest you check them before buying any more parts...
Agree, it looks like a bad head.
psychopat
I played around more with it last night, I did a flushing adjustment. Looks like it was set to -10 and the closest setting before it pushes on the carriage was -50.
I also tried to pull ink from below which worked fine so I guess the suction was good. Unfortunately results are still the same. I figured might as well try everything.
I bought those from Spicers, they are a Roland dealer here. There are only a very few in Canada and that's the cheapest place that I have found. Yes, all prices are in CAD and also there's a 15% sales taxes on top of those prices.
The print head is 3100$CAD, other quotes I got was 3300 and 3600.
6701409010
Assy, Head Inkjet VS-640
$3,100.00
Will look up on Solventinkjet.com thanks! with the new 25% tariffs applicable now from the US, might be cheaper to find a place in Europe or Japan. I'm hoping the head is still in stock otherwise the price I got quoted will be considerably higher from Spicers too. :(
The process to change the dampers was fairly easy, im used to fiddling around as my main job is to restore and fix arcade and pinball machines, electronic boards and rebuilding CRT monitors etc.
From the look at it, replacing the head should not be too bad, just a matter of moving the head cover with new dampers directly to the new head. Shouldn't even have any leaks either for this process, then reconnecting cables etc.
Other than head ranks and a calibration, is there any other adjustments recommended on those VS heads after replacement?
Thanks again for the advice, I live in a remote location and without any tech around makes it a lot more tricky.
coltonwanderson
Unfortunately as a Roland dealer tech, I agree that it's a bad head, looks like either physical damage to the face or a small crack in the manifold. If you can get an OEM they are very easy to replace. You've already done the dampers, which means you were basically already there. In fact, you don't even need to operate the choke for the head replacement. Just a few more screws. As for adjustment you just have the bias, (which might be fine if you are careful with positioning when you put it in) and then one digital adjustment.
If you go the upgrade route, I agree with Zoogi to stay away from the SG1. SG3 is nicer then the 2 but doesn't really offer any special functionality that the SG can't do, except maybe perforated cuts. Can't speak to the Mimakis though.
psychopat
Thanks for the tips, someone also mentioned that it looks like de-laminating and to try with a syringe to put solution through the head. If it comes out on the side then its de-lamination. I have been using aftermarket cleaning solution and apparently its not good for the head. I just ordered a bottle of ESL5 to use with the new print head in the future.
Thats great regarding the replacement, so just need to remove the cover with dampers which shouldn't really leak. Then replace the head and put those back. I didnt know there was an actual physical adjustment on the head, I thought it was just screws on it that can go only one way and the rest was printer calibration in the settings and making sure to check my flushing adjustment. Any tips on how to position it in there?
Since you are a roland dealer tech maybe you can answer that. I am purchasing the new head from a Roland authorized dealer. I was asking about the warranty on it as I have read in the past that sometimes they can have issues out of the box. They told me the 90 days warranty for Roland only applies if their own tech do the installation and register the head for warranty. Meaning that even if I would hire a certified tech from another company, the warranty on the head wouldn't be honored. Is that normal in the business or something I should be worried? Im not sure how common it is to get a defective head but sounds like I would be shit out of luck if that happens.
