Red color on flexi 8.6
Discussion in 'RIP Software & Color Management' started by PhantomNeon, Feb 22, 2010.
  1. PhantomNeon
    PhantomNeon Member
    58
    I have a big issues with red color in flexi8.6, I use colormunki, for my monitor profile, and set as profile on flexi color settings, and all that settings, but I never can get a real red, (only orange), I tried everything, but is really imposible. I change to RGB to CMYK, and other way, but the real red never appear, someone use some specific color swatch that show better colors ?
    Or any sugest ?
    Thanks . . . .
  2. bob
    bob Major Contributor
    5,275
    306
    83
    Nov 4, 2005
    earth
    It's perfectly possible and reasonable to hit a good red. You have to understand your gear and don't obsess with having the same color on your monitor that will come out of your printer. That way lies madness.
    Set your rendering intents to no color correction for everything except bitmaps. Set bitmaps to perceptual.
    Print a Pantone chart on the media with the profile you happen to be using, hang it on the wall, and when you need a good red, or any other color, pick one off the chart. Don't worry over much what it looks like on your monitor, you're not delivering that.
  3. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    I'm bumping this because I want to try it. I have done a chart, but want to look into the other details. I've improved my reds with double ink layers too, but of course that effects every color in the print... (& doesn't really effect the hue of course, but once I get close, darker opacity sometimes improves it more)
  4. scarface
    scarface Guest
    The only problems I've had with reds are they come out more grainy than any other color.
  5. bob
    5,275
    306
    83
    Nov 4, 2005
    earth
    True, the dither pattern seems more visible in reds. You can mitigate this some by opting for a higher quality dither algorithm. Supposedly the higher quality the dither algorithm the longer the RIP times. I routinely use the top of the line dither and I don't see any appreciable increase in RIP time over the general purpose algorithm.
  6. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    16
    KF diffusion doubles RIP time on my measly comp...but I usually opt for it...
