Red Tip vs. Blue Tip
Discussion in 'Graphtec' started by Valentino, Feb 15, 2007.
  1. Valentino
    Valentino Active Member
    675
    Jan 16, 2007
    Can someone please tell me the differences between the red tip and the blue tip?
    i know size, but i mean like in uses?
    thanks
  2. flexiezine
    flexiezine Member
    109
    Red tip is better for use with thicker material like sandblast, high intensity reflective, etc.
    Blue tip is ideal for softer, thinner materials like vinyl, ambermask, paintmask, etc.
  3. Sign Works
    Sign Works Very Active Member
    1,549
    67
    48
    Nov 25, 2006
    Sacramento, CA
    I'm assuming that you are refering to the blade holders, each is designed to accomodate different blades, refer to your Graphtec manual for proper applications.
  4. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    Bobby is right, the red tipped blade holder holds the 15U blade for thick materials, & the blue tipped holder holds the 09U blades for regular 2 & 3 mil vinyl
