Click to Support Signs101 ...
i'm confused....you can use any punched material through a gerber machine....i'd suggest fdc if you're not using gerber 3m reflective....i would NOT suggest avery
I'm not sure if this is true. I just tried a test with Nikalite 4800 reflective material that is punched. It prints terrible. It will run through the plotter fine if you want to cut it but I dont think all materials are thermal coated to run through a thermal printer.
