registration marks disappeared!
Discussion in 'Flexi' started by mark in tx, Jan 22, 2007.
  1. mark in tx
    mark in tx Very Active Member
    2,081
    Oct 25, 2005
    Harker Heights, Texas
    I went to do some print, laminate, and cut stickers, but when I select "Contour", the registration marks option just says "None" and the drop down menu has nothing in it.
    Is there something I am forgetting?
  2. signage
    signage Major Contributor
    9,494
    71
    48
    Oct 5, 2005
    Penn
    Mark are you sure you have a cut line selected? don't need reg. marks to just print.
  3. mark in tx
    2,081
    Oct 25, 2005
    Yep, have a contour line.
    Need the registration marks so I can reload and cut after laminating.
  4. Color Dude
    Color Dude Member
    217
    What version of Flexi?
  5. Mike Paul
    Mike Paul Major Contributor
    5,438
    8
    38
    Dec 30, 2003
    NJ
    In 7.6 there weren’t registration marks for the VersaCamm. To add reg marks go to Production Manager > Setup > Default Job Properties > Printer Options tab and place a checkmark in Print Crop Mark.
  6. mark in tx
    2,081
    Oct 25, 2005
    Mike,
    Having no problems with crop marks, when I go into production manager, select contour options, the "Registration Marks" dropdown no longer has any options, and the "Material" area is greyed out.
    That is where I used to select a registration mark and then send as print only.
    For whatever reason, those options and selections have disappeared after having used them for quite a long time now.
