Registration Marks Inside the Design Area
Discussion in 'Graphtec' started by MrSalumi, Jan 18, 2013.
  1. MrSalumi
    MrSalumi Member
    373
    Oct 27, 2012
    earth
    Hey everyone. I've run into this problem a few times now and it's starting to get old. I'll layout in Illustrator CS5, use cutting master 2 to ad reg marks, print, lam, load into the graphtec FC5100-150 and try to cut.. I get an error that says "Registration marks cannot be used because they are not completely outside of the design area" But they are!!! WTF? Am I missing something?
  2. WI
    WI Member
    182
    I assume you're getting that from the CM2 application inside Illustrator? Make sure you've only got the path you're cutting selected. Failing that, see if nudging up the size of your artboard (not your registration marks) doesn't help.
  3. MrSalumi
    MrSalumi Member
    373
    Oct 27, 2012
    earth
    Yep it's coming from CM2.. I'll try bringing in the artboard but it seems like I've done that the last time it happened. Anyway, I'll try again. Also, I've never even realized which layers are selected when I cut... I'll try that too. Thanks!
