Registration marks with home/office printer?
dj_elite
Im running Flexi 8.5. Is there a way to print on a home/office printer with registration marks? When I click to print the registration marks do not show, but will show for my large format printer. Is there an option to turn this on?
Most plotters will allow you to manually create a registration mark in your design software. I'm not sure which model plotter you are using but you should be able to look up the mark specs and create them in your design software. Then you just add them to the file and print like normal and cut form your cutting software. It's not as ideal as having Flexi to do it all for you but it should work.
