Registration marks with Illustrator CS2
Discussion in 'Adobe' started by oc63rag, Jun 11, 2007.
  1. oc63rag
    oc63rag Member
    237
    I'm setting up some files to cut and I need to print out registration marks. I've checked the box in Files>Print>Marks & Bleed and they still don't show up on the output.
    What am I missing?
  2. Sign_Boy
    Sign_Boy Major Contributor
    6,429
    8
    38
    May 18, 2007
    USA
    This is gonna sound silly but in the print dialog box after you click "Marks and Bleed" and have Registration Marks checked, scroll over the view finder with your image in it. A hand will pop up click and move it around and see if the registration marks are within your print area.
    I hope that helped.
  3. oc63rag
    oc63rag Member
    237
    They sure are. They're up in corners way out of view. How do I get them inside the print area so I can use them for cutting?
    Thanks for the help.
  4. Sign_Boy
    6,429
    8
    38
    May 18, 2007
    USA
    Click "File" then "Document Setup" Change the size of your atrboard. That should do it.
    Hope that helped.
  5. oc63rag
    oc63rag Member
    237
    Perfect. Thanks for the help.
  6. Sign_Boy
    6,429
    8
    38
    May 18, 2007
    USA
    No problem any time
