If you use Corel Draw, add a color to your palette and make it a spot color. Choose any color you want, generally I use Pink because it's a color I never use in a job.
Name the color "CutContour" exactly like that.
Then on your object, right click to make the outline CutContour, import into Versaworks and it will see it and just do cut only.
Roland CutStudio will see your EPS file already as vector and you don't need CutContour. Just design, export, import and cut.
