Remove UV print?
Discussion in 'Digital Printing' started by juan45215, Aug 5, 2020.
  1. juan45215
    juan45215 Member
    482
    3
    18
    Aug 6, 2004
    Cincinnati OH
    I had a contract printer print a design on to a white acrylc substrate with a flatbed printer. Unfortunately, it turned out to be the wrong design.
    Is feasible to remove the image and reuse the substrate or do I have to throw it away?
  2. RaymondLoewy
    RaymondLoewy Pretty fly for a Sign Guy
    In the past I have removed FB500 inks from clear acrylic using VHB tape, they were small 6x6" squares so it was easy.
  3. Gino
    Gino Premium Subscriber
    33,495
    2,387
    113
    Jun 7, 2006
    PA
    A razor blade will do the trick.... and it ain't hard to do. Just get the right angle and you can sail right through it.
    • Like Like x 1
    • OMG / Wow! OMG / Wow! x 1
  4. StarSign
    StarSign Active Member
    650
    75
    28
    Sep 20, 2011
    Southern Utah
    There still could be some ghosting if you can get the print off.
  5. bob
    bob Major Contributor
    5,275
    306
    83
    Nov 4, 2005
    earth
    The short answer is NO. Not if you're supposed to be a professional at this. Someone, most likely you, is going to have to eat the price of new substrate. If you want to do it right.
    • Agree Agree x 1
  6. Zach Starr
    Zach Starr Head of Printing Operations
    47
    3
    8
    Nov 9, 2018
    Santa Ana, CA
    You can try using the cleaning flush, apply that first and carefully remove it. You can remove it with that, and keep as piece for future testing, and get new printed for the customer. That way you would have something atleast to do test on.
    • Like Like x 1
  7. thesignpost
    thesignpost Member
    39
    4
    8
    Nov 3, 2011
    Las Vegas
    A professional would replace the substrate.
  8. Gino
    33,495
    2,387
    113
    Jun 7, 2006
    PA
    Yowsa........ I consider myself a professional for the most part and I just did this a few weeks ago. Printed a panel and something stopped it and it double printed a section about 2 inches long. While we were doing the others, I took the panel to the back room and proceeded to just scrape the ink off. It came off swimmingly. No scratch makes, no hazing, no nothing. The piece was about 42" x 72". Took maybe 15 minutes. Then, for Murphy's Law sake, I flipped the piece over and printed the other side. Guess what, you couldn't tell a thing and this was not the first time we ever did this. Sometimes ya get a head strike and too much ink goes down..... samating.
    Now, if I hadda do a series of them.... or a 5' x 12', no way, but my own in-house mistake..... why not ?? I think it's more professional to know how to fix a mistake than just discarding it, in some cases.
    • Like Like x 3
    • Agree Agree x 2
  9. JBurton
    JBurton Signtologist
    1,898
    380
    83
    Sep 28, 2017
    Arkansas
    Who said this was the sign company's fault(or OPs fault)?
    I've reprinted and reapplied stuff for customers time and again that they approved.
    This very well may be the very same scenario.
    • Agree Agree x 1
  10. Bly
    Bly Very Active Member
    3,067
    372
    83
    Mar 9, 2004
    Sydney
    We use graffiti remover to soften the inks enough to peel off, then print on the other side.
    • Informative Informative x 2
    • Agree Agree x 1
  11. peterprintingparty
    peterprintingparty Member
    25
    3
    3
    Jun 20, 2019
    New Mexico
    I've had to remove UV ink from a 1/2 inch acrylic art piece. We did not want to eat that cost. So we drowned the print in denatured alcohol and it wrinkled right off. Super cool looking, and saved the large piece of acrylic to re-do
    • Informative Informative x 1
  12. juan45215
    juan45215 Member
    482
    3
    18
    Aug 6, 2004
    Cincinnati OH
    Thanks everybody. The razor worked great. Saved me a hundred bucks.
    • Like Like x 2
  13. rossmosh
    rossmosh Active Member
    666
    172
    43
    Oct 9, 2014
    New Jersey
    Obviously you print on the other side, but as we all know, acrylic shows minor imperfections pretty easily if you're looking for them. A trick is instead of trying to keep the glossy finish, grab an orbital sander, and sand it down to a matte P95 finish. It probably won't look like a factory P95 finish, but you can get close using worn down 180 grit paper. Personally, I prefer the look of matte acrylic anyway. Gloss shows too many imperfections. Matte hides most of them, especially on opaque acrylic.
    • Agree Agree x 1
