we made one ...
yes afterall it is not difficult..
a separated part on the forum would be great for similar issues..
before the connect we made a dodge van that was simple.. because after loosing up the screws on the door edges the handle comes out.. (flipped out)
on the connect..
i describe the order i could figure.. others might have more simple way..
first interior panel removed ....
behind interior handle a small tab, need a picker to flip out also the interior ""grabber"" has the lid you remove and behind two
screws..
next the lock cylinder under the handle.. pull out the clip inside ..
put key into cylinder open lock, and with a screwdriver push the tab on the cylinder side, inside in the door..
twist the lock and it comes out
next detach the small rod that connecting between doorhandle and lock unit inside..
it is a plastic ""snap"" ... open and pull towrd you the rod that has a little thread on its end
here i removed the glass rail, that closer to the dooredge.. 3 M6 bolts hold it.. it might not necessary, however made further work easier..
next on the door edge, you see 3 screws, bolthead around the door latch.. turn off themm and lockmechanism falling down inside
now you can llok trough on the opening where door latch with lock mecanism was located, and you can see a panhed screwhead with star bit 30 mightbe other size,... i dont know the size i tried one that fit..
turn out the screw and you will ""feel"" it is out, then turn back about 2 turn..
next with a plastic pry off the small lid front of the handle
now you can flip out the handle..
hope it helps the next readers.. for me took hours unfortunately to finding out..
i also was thinking on the back doorhinges.. life would be lot simpler without them
