VicoDrive
Looking to put some decals onto a vehicle which will require removing a couple of the F250 Ford logos and the long rubber bump guards along the bottom of the doors. Never done this before, do you really just pry it off with something like a plastic window scraper or is there something you should spray behind it to get it to loosen? Also, after its removed, is there left over adhesive that should also be removed? And if so, whats the best way to get rid of it?
