Rualsignmaker
*Edit* I plugged the ribbon cables into the head right but into the board reversed. Fuse is confirmed popped. How do we know if the head is bad now too? or just swap the fuse because that's its job anyways?
Followed the Roland manual on replacing a print head on my SP540. The old one had high kicks and damage to the head. Leaked magenta.
The replacement head doesn't work. I had a strong vacuum when I primed the new dampers. No leaks.
Checked the F3 fuse and it doesn't go near 0 on the meter. F2 is good. Is it a bad head or did I pop the fuse? or both?
Which route is the best to go? Replace the fuse and if it pops again then replace the new head?
