Open the bitmap in Flexi. Select the bitmap and go to the Bitmap menu > Resample. A good rule of thumb that I was taught is you only increase it by three times. For instanced if it says that it is a 500x500 pixels change it to 1,500x1,500. The reason for this is after adding three times the resolution you are just going to increase the file size more than you will increase the image quality.
