By deselecting "RESAMPLE IMAGE" you should see the resolution go higher while the document size goes lower, so at the very least you maintain the same pixel count for the area it represented... if it was pixelized at the original size, it should look the same if you resample the image....and for production/archive purposes I would do a "SAVE AS"
